Home > Technical (L322) > 3.6 TDV8 issues following split boost/intercooler hose
Page 8 of 19 <123 ... 789 ... 171819>
DMRR
Thinking on this - if removing the bottom hose kind of relieves the issue for a short while, I wonder if there's something in the intercooler and removing the pipe is allowing any pressure to drop and the blockage move (although quite what could in the intercooler apart from oil I'm not sure!) Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #510853 4th Apr 2019 10:50am
Weegie
@ MW
Are you using the old hose clips or new ones. It might be that the clips are defective (even if new) in that, when you reinstall, they are tightening up correctly but after a short run they are slackening off even slightly.
It might be an explanation for the way it is reacting. John
GAP iiD BT-Sold
Post #510854 4th Apr 2019 10:51am
DMRR
Genuine hoses come with the clips - I am guessing the silicon ones don't .... Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #510856 4th Apr 2019 10:54am
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
DMRR, I think its the top hose that is being removed and replaced. He also put a new genuine LR hose on at first.
Marianna, for the next few days everytime the symptoms appear remove that hose and if it cures the issue I think the only thing to do is romove the throttle bodies and manifolds and thoroughly clean them out. Its looking more and more likely that you've been unlucky and bits of the old hose are stuck somewhere.
Another check to make is the firmness of the hoses immediatly afrer switching off the engine. Compare the two top hoses. I suspect the hose with issue will be firmer indicating a blockage. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #510861 4th Apr 2019 11:03am
MarianaWestminster
That's correct Grofus,
Its the upper n/s intercooler to inlet manifold hose im talking about.
I replaced the split one with a new genuine LR hose shortly after the split happened.
I noticed the drive ability concerns straight away and it was suggested on an RR facebook page that I fit silicone hoses which I did less than 2 weeks later.
The split was about 2 - 3 inches long and very clean, there wasn't really any hose material lost. A picture might explain this better.
I will repeat the procedure each time the car starts to drive poorly and see how I get on.
I wonder if a terraclean would be of benefit?
Post #510868 4th Apr 2019 12:39pm
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
Are you leaving the plastic top engine cover off?
It may be interfering with the MAP sensor wiring in some way. I think you’ve mentioned that you’ve also had success (although short lived) after cleaning the MAPs.
Another post here mentions a similar issue was caused by loose wiring. The engine cover maybe causing this, rather than you removing the hose and refitting it, if you get me drift.
Remove engine cover, just for a giggle 2007 3.6 TDV8
Post #510878 4th Apr 2019 1:03pm
Grofus
ok, the split is typical. Usually under the webbing sleeve.
What is puzzling is removing the hose gives a temporary cure. As if relieving pressure is allowing something the fall clear.
A terraclean may be worth doing after the problem is found. I would, at this stage, strip it down and closely inspect parts. You could otherwise be chasing it on and on.
Do keep removing the hose to make sure of its effect for a few days. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #510881 4th Apr 2019 1:10pm
Mikey
Have you taken the bottom hoses off yet?
Post #510883 4th Apr 2019 1:18pm
DMRR
Just to be clear here on diagnostics - are you using IID (or equiv), or just an OBDII reader?
I only ask because the generic ODBII readers do *not* show certain induction faults. Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #510884 4th Apr 2019 1:19pm
MarianaWestminster
Bottom hoses have been off and checked mikey.
I am using JLR SDD V138 for diagnostics
Post #510889 4th Apr 2019 2:49pm
cheezels
Any news Mariana? 2007 3.6 TDV8
Post #511206 7th Apr 2019 12:03pm
MarianaWestminster
Sorry ive not updated,
Been a hectic weekend and havent used the RR atall really.
Will update this week
Post #511312 8th Apr 2019 10:01am
MarianaWestminster
Right, back to it.
So I can confirm now with certainty that removing the hose shown in this crudely edited picture and reinstalling it makes the car drive nicely for a short while.
It was this hose that split originally, was then replaced with the LR hose and eventually the silicone pictured etc.
I have scoured the area and nothing seems broken/unplugged/amiss.
Obviously something must occur when i pull the hose and reinstall. I am going to feed my boroscope camera into the inlet manifold tomorrow evening to have a look.
Post #511611 10th Apr 2019 10:08pm
MarianaWestminster
Helps if I add the picture... doh
Post #511612 10th Apr 2019 10:09pm
MarianaWestminster
Third times the charm.. is it possible to edit posts?
Post #511613 10th Apr 2019 10:10pm
