Home > Maintenance & Mods (L322) > Bottle Jack Modification to replace Scissor Jack
Page 6 of 10 <12345678910>
MrSkill
Just purchased one of the Mercedes Sprinter bottle jacks from a guy in Swindon and found out he has loads more in case any one interested;
They are all brand new and he is asking £35.00 plus 8.95 p&p posted with MyHermes.
Contact Dan Watson; Dan@watsonoils.com
No connection to me, just thought I would pass on in case of any interest.
Post #422584 13th Jan 2017 3:32pm
Andy
Must convert mine! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #516057 21st May 2019 9:40am
200AD
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
I bought a merc sprinter jack recently and used it unmodified to lift my fatty to gain acess to the rear right suspension.
No dramas lifted the car easily.
Job jobbed!
Post #517171 1st Jun 2019 9:21pm
Nick591
Just fyi. Dan at watsonoils does not have any more sprinter jacks. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #517433 4th Jun 2019 5:46pm
Nick591
Doh! Lesson to self. Read post date before emailing! Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #517434 4th Jun 2019 5:48pm
GGDR
The aluminium BMW /mini blocks are back on ebay for cheap money:
https://www.ebay.co.uk/itm/BMW-AND-MINI-JA...%7Ciid%3A1
Anyone who doesn't have a sprinter jack, you need one. Plus one of these blocks..
They come and go availability-wise, they were on for silly money a while back.
I guess they made a new batch.
. Cheers, Greg
Post #539869 8th Jan 2020 9:47pm
DrRob
Thanks Greg Thumbs Up
Can these be used to provide a flat surface for a trolley jack? 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
New Defender D300 90 on order so "Rory" will be going to a new home....!
Post #539871 8th Jan 2020 10:01pm
GGDR
Yes I believe so Rob although I've not tried that.
There are a few threads on sprinter jack / blocks, here are a couple:
https://www.fullfatrr.com/forum/topic49118-45.html
https://www.fullfatrr.com/forum/topic48661...p;start=30
I've had a Sprinter jack for a while but I need to do the mod.
I'm personally going to copy Geoff's solution and go the steel route. Cheers Geoff Thumbs Up
Geoff's (supershuttle) pic:
 Cheers, Greg
Post #539874 8th Jan 2020 10:26pm
DrRob
The metal ones in your links are 55 x 30mm. Is that right size? 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #539875 8th Jan 2020 10:32pm
GGDR
Rob I remember reading on one of these threads that somebody did a simple mod to their trolley jack so it locked onto the aluminium block. Can't find it. It might have even been attached to the trolley jack.
. Cheers, Greg
Post #539876 8th Jan 2020 10:32pm
DrRob
supershuttle wrote:
I don't seem to have the option to upload pictures anymore it started but didn't finish, probably operator error Very Happy but when it comes back I will.
The key dimension is the rectangle viewed from the top should be 30mm x 55mm the 30mm is really tight but you could happily be a bit over on the 55mm - say 57mm maybe. Obviously if you get a measurement from someone who has bought the official BMW bit they would be the ones to use. Thumbs Up
Looks like 30mm is just right Thumbs Up
Going to order and then feedback. I have the SGS trolley jack..3tonne one
https://www.sgs-engineering.com/tj3x-3-ton-trolley-jack
Adaptor will sit nicely on the rubber pad that came with the jack Thumbs Up 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #539877 8th Jan 2020 10:33pm
GGDR
Yep, from page 2 of this thread:
 Cheers, Greg
Post #539878 8th Jan 2020 10:33pm
GGDR
Snap Cheers, Greg
Post #539879 8th Jan 2020 10:34pm
DrRob
I’ll start a new post showing my 2 jack options for any new folks. Easier to describe than words Whistle Thumbs Up 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #539880 8th Jan 2020 10:47pm
Baltic Blue
I can provide pictures of the exact measurements when you start your new thread ,if it helps you.
Post #539901 9th Jan 2020 9:55am
