![]() | Home > Maintenance & Mods (L322) > Bottle Jack Modification to replace Scissor Jack |
MrSkill Member Since: 08 Nov 2012 Location: England Posts: 62 ![]() ![]() |
Just purchased one of the Mercedes Sprinter bottle jacks from a guy in Swindon and found out he has loads more in case any one interested;
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2951 ![]() ![]() ![]() |
Must convert mine! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Nick591 Member Since: 04 May 2017 Location: Seaton Dalaval Posts: 193 ![]() ![]() |
Just fyi. Dan at watsonoils does not have any more sprinter jacks. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
Doh! Lesson to self. Read post date before emailing! Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561 ![]() ![]() ![]() |
The aluminium BMW /mini blocks are back on ebay for cheap money:
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
Thanks Greg |
Yes I believe so Rob although I've not tried that.
The metal ones in your links are 55 x 30mm. Is that right size? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Rob I remember reading on one of these threads that somebody did a simple mod to their trolley jack so it locked onto the aluminium block. Can't find it. It might have even been attached to the trolley jack.
Looks like 30mm is just right ![]() Going to order and then feedback. I have the SGS trolley jack..3tonne one https://www.sgs-engineering.com/tj3x-3-ton-trolley-jack Adaptor will sit nicely on the rubber pad that came with the jack ![]() 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- Last edited by DrRob on 8th Jan 2020 10:46pm. Edited 2 times in total |
Yep, from page 2 of this thread:
Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
Snap Cheers, Greg
I’ll start a new post showing my 2 jack options for any new folks. Easier to describe than words |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3880 ![]() ![]() ![]() |
I can provide pictures of the exact measurements when you start your new thread ,if it helps you.
