Home > Maintenance & Mods (L322) > Bottle Jack Modification to replace Scissor Jack |
MrSkill Member Since: 08 Nov 2012 Location: England Posts: 62 |
Just purchased one of the Mercedes Sprinter bottle jacks from a guy in Swindon and found out he has loads more in case any one interested;
13th Jan 2017 3:32pm |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2926 |
Must convert mine! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
21st May 2019 9:40am |
Nick591 Member Since: 04 May 2017 Location: Charfield Posts: 193 |
Just fyi. Dan at watsonoils does not have any more sprinter jacks. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
4th Jun 2019 5:46pm |
Doh! Lesson to self. Read post date before emailing! Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
4th Jun 2019 5:48pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
The aluminium BMW /mini blocks are back on ebay for cheap money:
8th Jan 2020 9:47pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4228 |
Thanks Greg
8th Jan 2020 10:01pm |
Yes I believe so Rob although I've not tried that.
8th Jan 2020 10:26pm |
The metal ones in your links are 55 x 30mm. Is that right size? 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
8th Jan 2020 10:32pm |
Rob I remember reading on one of these threads that somebody did a simple mod to their trolley jack so it locked onto the aluminium block. Can't find it. It might have even been attached to the trolley jack.
Looks like 30mm is just right Going to order and then feedback. I have the SGS trolley jack..3tonne one https://www.sgs-engineering.com/tj3x-3-ton-trolley-jack Adaptor will sit nicely on the rubber pad that came with the jack 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" New Defender D300 90 on order so "Rory" will be going to a new home....! 1974 Series 3 Lightweight = "Millie" My preferred specialist: www.glenrands.co.uk -------------------------------------------------- Last edited by DrRob on 8th Jan 2020 10:46pm. Edited 2 times in total |
8th Jan 2020 10:33pm |
Yep, from page 2 of this thread:
Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
Snap Cheers, Greg
8th Jan 2020 10:34pm |
I’ll start a new post showing my 2 jack options for any new folks. Easier to describe than words 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
8th Jan 2020 10:47pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3676 |
I can provide pictures of the exact measurements when you start your new thread ,if it helps you.
9th Jan 2020 9:55am |
