Home > Maintenance & Mods (L322) > Oil removal 4.4L TDV8
Page 7 of 13 <123 ... 678 ... 111213>
Baltic Blue
I have an old plastic tundish that I have had many years that I use for oil , then clean and use for washer bottle .
I pour first 5 litre can in directly to the tundish, but then I have an old plastic measuring jug and I put one litre at a time in using that for the next 3 litres, then to top up in 0.25 litres as necessary.
Post #525040 16th Aug 2019 10:19am
DrRob
Exactly my thoughts Mike Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #525044 16th Aug 2019 10:59am
nino_nino
I made one from 1L Mobil 1 oil can. it fits really nice and tight . Thumbs Up
 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #525074 16th Aug 2019 3:54pm
DrRob
Thumbs Up Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #525078 16th Aug 2019 4:10pm
ffaffage
I did my first service yesterday afternoon, picking up the Draper extractor as recommended above - thanks all!
I have to say, that was the easiest and cleanest service I've done on a car. Draining the oil and swapping the filter is far easier with it all accessible from the top rather than lying underneath. I'll probably want to do an old school emptying from the drain plug at some point just to flush out anything lying on the bottom though.
Hardest bit was pushing the new fuel filter back on (airbox removed to give access), and even that was only stiff.
Post #525990 24th Aug 2019 7:57am
GGDR
Got a used Draper pump thing off ebay...
Pumping for 15 mins and not a sausage.
I didn't get an instructions, mainly interested to see if I can replace the seals.
Or missing something obvious...
Manual's not on the Draper website for some reason.
While I'm back to the seller Censored ...
...does anyone have a manual for the Draper 77057
. Cheers, Greg
Post #526079 25th Aug 2019 3:03pm
ffaffage
Here it is - though not very useful Sad
Post #526082 25th Aug 2019 3:19pm
GGDR
Thank you!!!!
Thumbs Up Thumbs Up Thumbs Up Cheers, Greg
Post #526083 25th Aug 2019 3:20pm
GGDR
Above says pump it for a bit. Then open the air valve
Tried that just now but nothing.
When I'm pumping, no matter how many strokes, there's no resistance.
Doesn't seem to matter where the blue valve handle's position is...
I'm kind of expecting it to work like one of those garden sprayers, you pump for a bit and you can feel resistance the more you pump...
Am I doing it wrong?
. Cheers, Greg
Post #526084 25th Aug 2019 3:25pm
ffaffage
I just used mine with the "air control valve" in line with the pump handle (rather than at 90 degrees to it).
Pumping the handle, you can hear air coming out of the multi-holed head next to the pump handle - just as if you were using a pump for an airbed. I've just verified that. At this point, it'll start sucking through the hose. In use I didn't notice any massive difference in effort pumping. Pumped it a few times, oil started being sucked. Left it to it whilst I did other bits, came back and pumped a few more times.
Post #526085 25th Aug 2019 3:36pm
GGDR
Air coming out of the bit with 7 holes? Nothing. Seals might be gone...
(I thought that was storage)
 Cheers, Greg
Post #526090 25th Aug 2019 4:15pm
ffaffage
Sorry, got that wrong Embarassed
Was playing with it in the box, it sounded as if it came from there.
On the black tube at the back that runs top to bottom, there are two small horizontal holes in the plastic cube at the top - one points in towards the oil reservoir, one points outwards. The air pumps out of those, covering them with a couple of fingers makes it impossible to push the pump handle downards.
Post #526092 25th Aug 2019 4:19pm
Baltic Blue
Greg,
Sorry to read that you are struggling with the pump.
I have just got home after a very hot and sticky motorway trip.
If you need any further help I will get mine out of the garage to refresh my brain, but it didn’t come with any instructions when new.
Cheers
Post #526094 25th Aug 2019 4:31pm
cass
My guess is a faulty pump- I had one a few years ago and had used it loads of times no problem. Lent it to a mate who decided to suck the petrol out of a chainsaw with it, seems that petrol wrecks the seals.
I put new seals in but it was still hopeless so ended up getting a new one.
Post #526095 25th Aug 2019 4:39pm
GGDR
ffaffage - would you mind giving me directions to the holes:
 Cheers, Greg
Post #526101 25th Aug 2019 5:29pm
