![]() | Home > Maintenance & Mods (L322) > 4.4 tdV8 turbo oil drain mod. |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3270 ![]() ![]() ![]() |
With lockdown and little use, have your seals dried out and failed to an extent? John
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 147 ![]() ![]() ![]() |
I think there is a good possibility that it is the case |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
It does, so why the scavenge pump??? The parts involved....
2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8771 ![]() ![]() ![]() |
Possibly due to positive crankcase pressure, but really, just guessing.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
It's the sump:
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3875 ![]() ![]() ![]() |
I started this thread back in 2016.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2743 ![]() ![]() |
I don't specifically know why the slow drive allows oil to build-up without the extra, direct to sump drain but it suggests that the turbo's seals have become very weak to the extent that the scavenger pump can't produce a low enough pressure.
That makes sense, thank you. BMW i3 Electric Car
Digressing a little, a new early 3.0 RRS here in Oz eventually had the engine replaced under warranty when serious smoke couldn't be stopped by multiple new secondary turbos then a new scavenger pump. It seemed that the oil-way connecting the turbo drain reservoir at the bottom of the sump with the scavenger pump at the top of the back of the right head must have been blocked or severely restricted. This was when LR was replacing lots of turbos, including my D4's, thinking that the turbo's seals had failed rather than the real cause. My D4 was due for another turbo just after the end of warranty but still covered for the earlier fault when the updated drain was released which I then fitted myself, being more convenient for me. |
Thanks GraemeS for a very good explanation of this problem.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4345 ![]() ![]() ![]() |
If it continues after multiple "boots" then a drain might be needed.
Previous week booted it a few times and no smoke :DVisiting gamepark tomorrow,so plenty slow travelling!This will be the test.Will report back!
Ok did do the trip to gamepark.
AngelsBoy Member Since: 31 Jul 2020 Location: Prague Posts: 20 ![]() ![]() |
Hi GraemeS, And when a refurbished turbo is installed, including new seals (absorbs most of the pressure). Where does the excess oil go? To the exhaust? Or can it go through the radiator to the engine ...? |
