Home > Maintenance & Mods (L322) > 4.4 tdV8 turbo oil drain mod.
Page 11 of 15 <123 ... 101112 131415>
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Brave man, good luck, watching with interest. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #586150 4th Mar 2021 4:19am
Fat Lad
steve57060 wrote:
Managed to find kit for mod LR045004 on ebay
Coming from germany at £80 inc delivery
Will hopefully be starting job next week
Please follow up if you get the chance Steve, noticed a big plume on ours for the first time last week so I suspect this job is on the horizon.
Good luck!
Ritch 1996 Disco 1 3.9 V8 on gas (Sadly Sold)
1996 Disco 1 300 TDI S (Thankfully Sold)
2004 Disco 2 TD5 ES (Sadly Sold)
2005 Disco 3 TDV6 HSE (Thankfully Sold)
2011 RR Vogue SE TDV8
Post #586304 4th Mar 2021 9:47pm
GGDR
steve57060 wrote:
Greg thanks for pic Noticed previous links to this mod that you were looking at getting yours done
Did you ever do it and what were the results
Nah, I've no garage and not only do you need a garage, you really need a ramp.
If I had those, I'd be there 100%
I initially concluded, looking at that sump pic and the gallery circled, that you would be drilling into the gallery alone.
But reading the instructions a few more times gave me a feeling you do have to drill though the two walls and into the main sump chamber.
Whilst Graeme's right about swarf pulling backwards, it's aluminium swarf and if any gets into the sump the magnet (assuming there is a magnet) won't pick it.
£80's a nice sweetener though!
AJG had studied your pics many a time but I hadn't seen the subframe dropped. Impressive in itself. Thing is if the subframe's dropped, I wonder why you wouldn't whip the sump off, sort the drain, flush it all and refit....? Dunno. Probably a good reason but worth thinking though...
. Cheers, Greg
Post #586323 4th Mar 2021 11:11pm
AJGalaxy2012
I suppose I probably would drop the sump as you say. Just thinking it through though, how likely is dwarf going to get in the sump? Highly unlikely if care is taken, if it did how much would get through the strainer and if that did happen a tiny fragment of soft aluminium how much damage would happen. I think the chances are zero.
I’d still drop the sump though if I was doing it 😂 BMW i3 Electric Car
Post #586348 5th Mar 2021 10:10am
JCW
Dwarf in the sump is definitely not good!
Post #586351 5th Mar 2021 10:52am
GGDR
I mean if he could sort out better draining I'm fine with it.. Rolling with laughter
AJG Thumbs Up
. Cheers, Greg
Post #586352 5th Mar 2021 11:09am
Edward
Hi, what sort of oil consumption are people experiencing with this problem?
Post #586419 5th Mar 2021 8:10pm
steve57060
United Kingdom 2017 Range Rover Vogue SDV8 Loire Blue
Oil consumption is not noticeable as amount in sump is vast
Just would like to sort this to tick of list
Not very desirable when you do push it
Already done o rings, oil cooler seal exhaust temp sensor
Looking at keeping car as nothing will be built like this again (massive torque)
Still cant tick off sat nav upgrade and battery low please start engine (mission too far) 2017 sdv8 4.4 vogue
2011 4.4 tdv8 (present)
2005 td6 vogue
2001 4.6 vogue (lpg conversion)
1999 2.5 diesel vogue (slowest car ever driven)
1996 4.6 vogue
Plus a couple of freelanders
Post #586431 5th Mar 2021 11:35pm
AJGalaxy2012
LOL, big fingers, small keys on the phone, no dwarfs were harmed in the mod. BMW i3 Electric Car
Post #586438 6th Mar 2021 6:45am
Edward
Fair enough, I am thinking the same about mine (keeping it). I have the engine out of mine currently to fix general oil leaks and to find the source of quite a significant usage of oil - about 1.5 L in 200 miles... Lucky it does have such a vast sump!
Post #586444 6th Mar 2021 8:11am
GGDR
Edward set up a post, not that many engines come out, well not many here... we'd love to learn about your findings. Assume you have a 4.4TDV8 ?
Twin turbo diesel V8 - a titan that is unlikely to return
. Cheers, Greg
Post #586445 6th Mar 2021 8:45am
steve57060
Taken time to reply as needed to test result. Good news seems to be no more smoke above 3000 rpm.
Dont go there very often as no necessity. Managed to get kit from Germany eventually as it was retuned to sender first time for incorrect paperwork due to brexit. Eventually arrived at acost of £120 (still less than half price! The job itself was straightforward by removing LH driveshaft Etc. The main problem is the diiff is in the way of drilling. The diff cannot be removed without unbolting whole subframe and using jack to push it downwards. Once diff is moved forward access for drilling
the job is pretty straight forward using guide supplied with kit. Didnt remove steering column as may require resetting. Did whole job over couple of weeks as car sorn as it is only used for towing. Cant believe drain would cure problem but as everyone says turbos dont really go on the 4.4. 2017 sdv8 4.4 vogue
2005 td6 vogue
1996 4.6 vogue
Post #592732 29th Apr 2021 11:17pm
AJGalaxy2012
I'm with you on the disbelief, how can it really make that much difference...... but it does!
Well done that man, you did a very cheap fix there. BMW i3 Electric Car
Post #592738 30th Apr 2021 5:39am
landy95
You wouldnt happen to have the details of where you bought the kit from, if they are still available i will pick one up also.
Cheers. Also own a 1976 Land Rover 101 3.5 V8.
Previously owned:-
2012 Range Rover Westminster.
1991 Range Rover Vogue 3.9 V8.
Post #642227 6th Sep 2022 9:21pm
steve57060
Hi The item was on ebay in Germany at a garage clearance. There was a problem with Brexit paperwork but eventually arrived. The sellers were reluctant to send as all the paperwork had to be done by them. I think it was for the L405 but with a bit of bending it fitted OK. Can recommend as no smoke whatsoever now (minor miracle) for just 1 pipe. Well worth the effort. Think Maltings do mod kit but you will have to check
Regards Steve 2017 sdv8 4.4 vogue
2005 td6 vogue
1996 4.6 vogue
Post #642265 7th Sep 2022 10:18am
