![]() | Home > Maintenance & Mods (L322) > 4.4 tdV8 turbo oil drain mod. |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1011 ![]() ![]() ![]() |
I wonder how close the L322 "oil drain mod" is to the more recent L405 - as cannot find the L332 one anywhere ? |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2756 ![]() ![]() |
LR032130 is listed for L322, L494 & L405. The drain doesn't go anywhere near the diff, driveshafts or the sub-frame. |
jaguar3 Member Since: 25 Sep 2022 Location: Estonia Posts: 194 ![]() ![]() ![]() |
I also had done drain mode about year ago. In the beginning all looks nice, no smoke at all (at least seems so). But ater half year (10000km) of driving the smoke coming slightly back again. Not so much as before, but still.
I have regularly been paddling down the box to get the engine revving above 3000 rpm in the last few weeks, and have no smoke, it is obvious to me that the second turbo needs to be used now and again to prevent the oil build up
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3956 ![]() ![]() ![]() |
I'm of the same mind, it's easy to get above 3000rpm using the paddles on the motorway but try as I might I can't see any smoke in my mirrors. So I guess I should leave well alone, there is another possibility that it has already been done by the previous owner. Anyway when I see smoke I'll have a look |
landy95 Member Since: 04 Aug 2021 Location: West Midlands Posts: 86 ![]() ![]() ![]() |
I have just looked on ebay for LR032130 and to me this looks like the originally fitted drain pipe and not the upgrade. Correct me if I am wrong. Also own a 1976 Land Rover 101 3.5 V8. Previously owned:- 2012 Range Rover Westminster. 1991 Range Rover Vogue 3.9 V8. |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
The oild drain mod worked 100% for me, no more oil smoke, no oil consumption absolutely 100% solution.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
I never suggested that it would work for every car, I havent heard of anyone having the mod done where it hasnt worked though.
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 788 ![]() ![]() |
Has this not got "SCAM" written all over it?
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561 ![]() ![]() ![]() |
julien381 as a new member you are very welcome here and it seems you are in the trade so we value people like yourself.
Chap on Facebook has an alternative easy first try fix for smoke screens. Put a new pump on. Easy to access on top of engine.
https://www.facebook.com/groups/ffrrtech/p...158138682/ Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
https://www.facebook.com/groups/ffrrtech/p...934746971/ Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
