![]() | Home > Maintenance & Mods (L405) > Sunroof Drains - Just in time? |
ReggieMac Member Since: 10 Sep 2023 Location: Wolverhampton Posts: 279 ![]() ![]() ![]() |
The idea of the sleeve is that it extends inside beyond the end of the original drain hole so that if the original drain did become disconnected then the insert will hold everything in place, at least hopefully long enough until you detect it on your next regular inspection, and minimise any water ingress. _______________________________________________
I wish I could take credit for it but that belongs this chap at 'Critical Reviews' here https://www.youtube.com/watch?v=rQpp2mm-lH0 _______________________________________________ 2019 4.4 V8 Diesel Range Rover Autobiography, Byron Blue |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8128 ![]() ![]() ![]() |
You can also pull the headlining away, just in front of the rear grab handle and shine a torch up to see where the rubber tube attaches.
linus Member Since: 04 Jun 2025 Location: Herts Posts: 25 ![]() ![]() ![]() |
Hi, I was about to check the on my L405.
OK looking at the Critical Reviews YouTube video it looks like I just have to remove the trims and I will be able to see the drains. The sunroof doesn't need to open.
I think that the drains are only present with the opening roof. There's no reason for them to be there with a fully fixed roof, only for the opening mechanism.
Thanks, I am guessing but I assumed the panoramic roofs are interchangeable in terms of size and just fitted into the roof. The body is probably the same though which makes me think it should have them.
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1851 ![]() ![]() ![]() |
Relax, the fixed panoramic roof is bonded in, much like your windscreen, and there are no roof drains. ![]() |
Phew...I can strike that from the list of things to worry about.
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 701 ![]() ![]() ![]() |
Does the L322 suffer from the same issue ?
It would seem like it, according to this by powerfulukltd.
OK, thanks, new tool it is then |
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 392 ![]() ![]() ![]() |
Ok just checked mine and lucky I did, one side looks good the other not so…..
sullivj Member Since: 19 Jun 2025 Location: Gatwick Posts: 44 ![]() ![]() ![]() |
I wouldn't just leave it. It looks like there is quite a bit of corrosion in there, meaning it's only a matter of time before the pipe becomes detatched and then ALL of the water will flow down your A Pillar and into the floor.
