Home > Maintenance & Mods (L405) > Sunroof Drains - Just in time?
Page 3 of 3 <123
sullivj
United Kingdom 2014 Range Rover Autobiography SDV8 Santorini Black
I like the sleeve solution, I'm just concerned about what I can't see...
If the tube is badly rusted, it's not unthinkable that it could still fall away from the insert and leak water into the car.
Post #723084 19th Aug 2025 11:48am
ReggieMac
United Kingdom 2019 Range Rover Autobiography SDV8 Loire Blue
The idea of the sleeve is that it extends inside beyond the end of the original drain hole so that if the original drain did become disconnected then the insert will hold everything in place, at least hopefully long enough until you detect it on your next regular inspection, and minimise any water ingress. _______________________________________________
2019 4.4 V8 Diesel Range Rover Autobiography, Byron Blue
Post #723086 19th Aug 2025 12:07pm
ReggieMac
adara wrote:
Thank you so much ReggieMac for sharing the sleeve solution that simplifies the procedure immensely!
I wish I could take credit for it but that belongs this chap at 'Critical Reviews' here
https://www.youtube.com/watch?v=rQpp2mm-lH0 _______________________________________________
Post #723087 19th Aug 2025 12:10pm
You can also pull the headlining away, just in front of the rear grab handle and shine a torch up to see where the rubber tube attaches.
I gave mine a wiggle - one seemed solid, the other came off Big Cry So I've cleared out all the rusty remains of the original tube that was inside it and now need to reconnect it to the insert. However, I need another bit of pipe as the insert is all that remains and is narrower than the original drain. I'm guessing a short length of the Hep20 pipe will work best Confused
I also had one that was blocked at the exit as well - that's located in front of the secondary battery. Easy to clear with a bit of strimmer cable.
Almost there.......
Post #723118 20th Aug 2025 8:07am
Page 3 of 3 <123
