Home > My Range Rover > L322 5.0 autobiography Sumatra Black - ownership journey
pcourtney
welcome to RR ownership, most of us feel your pain Smile
Also Sumatra Black, such a gorgeous colour in the bright sunshine, specs of dark blue jumping out at you when you park her up and walk away smiling !
Post #723062 18th Aug 2025 10:31pm
theJAFman
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Baltic Blue
Thank you Pcourtney ill be doing a full correction detail and cermamic coating last.
Also i realised whilst sat in the boot! This is a clear glass car! Its tinted so ill remove those tooo yesssss
Ok all problems sigted at this point
Upper control arms almost perished but yet to fail
Will change both sides
Oil leak has been found its a very slow weeping rocker cover gasket it leaves no puddles or drops confirmed by feeling around the rear side of cylinder head
i would have hoped it was changed during chains but i guess not or full on rtv job
Might be hard to ignore as charger will be comming off
Tranfer case has also has a weeping leak not leaving a drop ill tigten the bolts by quarter turn and leave this
This is worst of the rust on the car
I will clean and coat both subframes then treat paint and wax all other sighting of surface rust.
Still no parking sensors or centre console lights this is either a fuse or module so i will have to dig into that later
Thats it for today! Grabbing 36mm spanner and 2 more 4t stands tomorrow
If i disconnect power to steps whilst deployed they should remain out from what i understood.
I will remove charger tomorrow, hopefully then jack it high amd even as i can and get to sealing all underside while i wait 1500 in parts
Post #723065 19th Aug 2025 2:26am
theJAFman
I am now ready for land rover ownership
Purchased 4x happy to see you auto rise 4tonne stands at 65 for all 4 could not help it!
The spanner is also mine can finally check snout play and finalise parts order
Post #723085 19th Aug 2025 12:05pm
theJAFman
Parts list finalised although some bits will be from other places
Chav wiring removed and buried not worth taking interior apart for it
Stupid size battery removed for a agm 95h correct size
Garage is not tall enough to lockout bonnet 😑 need a few more inches and stick shall suffice alongside struts being propped up
Opinions please
Remove tints or keep as it appears i have a clear glass edition
Post #723135 20th Aug 2025 2:35pm
