Home > My Range Rover > L322 5.0 autobiography Sumatra Black - ownership journey
Page 2 of 8 <12345678>
pcourtney
welcome to RR ownership, most of us feel your pain Smile
Also Sumatra Black, such a gorgeous colour in the bright sunshine, specs of dark blue jumping out at you when you park her up and walk away smiling !
Post #723062 18th Aug 2025 10:31pm
theJAFman
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Baltic Blue
Thank you Pcourtney ill be doing a full correction detail and cermamic coating last.
Also i realised whilst sat in the boot! This is a clear glass car! Its tinted so ill remove those tooo yesssss
Ok all problems sigted at this point
Upper control arms almost perished but yet to fail
Will change both sides
Oil leak has been found its a very slow weeping rocker cover gasket it leaves no puddles or drops confirmed by feeling around the rear side of cylinder head
i would have hoped it was changed during chains but i guess not or full on rtv job
Might be hard to ignore as charger will be comming off
Tranfer case has also has a weeping leak not leaving a drop ill tigten the bolts by quarter turn and leave this
This is worst of the rust on the car
I will clean and coat both subframes then treat paint and wax all other sighting of surface rust.
Still no parking sensors or centre console lights this is either a fuse or module so i will have to dig into that later
Thats it for today! Grabbing 36mm spanner and 2 more 4t stands tomorrow
If i disconnect power to steps whilst deployed they should remain out from what i understood.
I will remove charger tomorrow, hopefully then jack it high amd even as i can and get to sealing all underside while i wait 1500 in parts
Post #723065 19th Aug 2025 2:26am
theJAFman
I am now ready for land rover ownership
Purchased 4x happy to see you auto rise 4tonne stands at 65 for all 4 could not help it!
The spanner is also mine can finally check snout play and finalise parts order
Post #723085 19th Aug 2025 12:05pm
theJAFman
Parts list finalised although some bits will be from other places
Chav wiring removed and buried not worth taking interior apart for it
Stupid size battery removed for a agm 95h correct size
Garage is not tall enough to lockout bonnet 😑 need a few more inches and stick shall suffice alongside struts being propped up
Opinions please
Remove tints or keep as it appears i have a clear glass edition
Post #723135 20th Aug 2025 2:35pm
theJAFman
Tints removed all round!
I thought id have clear glass underneath!
How much of a wana be pimp chav do have to be to have tinted over the factory privacy glass!
Still much better
These chrome side grill came as apart of my design pack body kit
It came with black ones not sure which will look best till wheels are on
I hate the red calipers!
And speaking of wheels!
Took me a while to finalise centre caps
Indicators are orderd in clear already
Time to ceramic coat them tonight
I really prefer these side grills but they dont fit, is there way to make them fit?
Post #723146 20th Aug 2025 9:45pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
The old style side vents should definitely fit, good work Thumbs Up Thumbs Up
Post #723148 20th Aug 2025 9:50pm
theJAFman
How? Do i have to modify the pins or somthing?
I guess they can just fit
Post #723149 20th Aug 2025 9:54pm
theJAFman
Wheels coated and sealed
Post #723155 20th Aug 2025 11:59pm
pcourtney
I think the desgn pack body kit chrome side vents / grilles that you have go really nice with those shiny bright chrome wheels Smile
I was thinking of changing my grilles to 2006 Supercharged, but never found a decent pair, at the moment the grey grille colour kinda matches my shadow chrome alloys, so kind of looks OEM
my Vogue Sumatra Black car has standard grey vent grilles as seen below, have yours perhaps been painted black by the PO
Post #723181 21st Aug 2025 12:39pm
theJAFman
Thank you pcourtney i think i want old style triple slat at this point.
Todays shenanigans as im off tomorrow and wish to complete all underside works.
Made sure all wheel bolts come off before raising the car for the first time.
What a rubbish design in wheel bolts surely there must be a all stainless alternative? Need to look into this, had to butcher a few chrome covers
First maiden full jacking was a little scary but with the front covers off its easy to see all the good points.
Rear had to improvise which ended up working quite well
but new stands are barely tall enough to clear wheels so had to add some timber. I had a pair of ancient van stands for the front they worked better on the subframe that go like 75cm high but are not finely adjustable.
Never the less i made it all work and car is dead level with rear needing 1cm on the jack, once Gearbox service is done i can drop it.
In the end i decided to unplug the auto steps from below whilst deployed as i found this the safest way
Hopefully i wont be here often!
Post #723191 21st Aug 2025 1:59pm
pcourtney
Wrington stainless steel nuts are the highest quality you can buy Smile
Not cheap at £14.50 a pop = £290 for 20 - ouch !
https://www.wrington.co.uk/product/polishe...3-4-and-5/
Post #723194 21st Aug 2025 2:28pm
kevinp
I had a set of Wrington nuts off Pete and they are absolute quality.
Post #723197 21st Aug 2025 4:12pm
NOTSHARP
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Interestingly, my 2012 in Sumatra black, has side vents which are colour coded half black.
Steve. “He that strikes the venison first shall be the lord o' the feast.” — Shakespeare, King Lear.
2012 Vogue SE. 4.4 TDV8, Sumatra Black
Post #723198 21st Aug 2025 4:14pm
theJAFman
I cant justify that i got a titanium set for me m3 for 200 that price is steep there must be a halfway option
Or just replace like 5 oem ones and move on
Post #723199 21st Aug 2025 4:16pm
pcourtney
[quote="NOTSHARP"]
pcourtney wrote:
Interestingly, my 2012 in Sumatra black, has side vents which are colour coded half black Steve
That's interesting, and they do look really good on your car, maybe they did that for latest 2012 L322's , mine is August 2011, but probably manufactured earlier in the year, and is all the same plastic colour grey Smile
Post #723217 21st Aug 2025 8:43pm
