Home > My Range Rover > L322 5.0 autobiography Sumatra Black - ownership journey
Page 5 of 8 <12345678>
theJAFman
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Baltic Blue
Maiden voyage went well
Tanked it at its 2nd home all is well after a 20 miles test drive
My dad down to see the car i think he liked it as he volunteerd to check for coolant leaks
We then drove down to my grandad and said hello its been 26 years since he passed 2 days ago we were a tad late
I fitted a full interior led kit pricey at 84 quid but they dont flicker and fade in and out PO fitted some cheops ones that just got hot and barely output any light as well as flickering alot.
Next to source quality number plate and reverse lights
That green plus is oem sub i need to source one not sure which variant or all hk subs are the same? Help
Front door speakers rattle will need to change those too
PO fit the craziest twin amp bs cock with standard speakers.
Also need to find wireless headphones for rear entertainment? Help and the smaller remote is missing
Tomorrow is just 1 shock absorber oil undertrays and deep wash
Peace all
Post #723728 1st Sep 2025 1:10am
theJAFman
Its finally done....for Now!
Car still needs good mop touch up and sealing some random rubbers and speakers to fix
But its running well air shock was a strange date
The shock had a build date of 2011 but the bag was 2022
It was leaking from under top cap it was a Censored remanufactured unit top bolt was missing the collar to lock the plug into place and maybe not torqued fully either as it was short 2 threads compared to new one either way it was shot and because of top bolt unlikely suitable for repair
I will change the other side to a matching dunlop unit in due course
Changed the oil and fitted the under trays Did another 20 mile road test car is sweet thank god
After 2 hours of observation no more sagging shock
Off to france tomorrow!
Thank you all for your support
Ps iso fix points on this car suck azzz
Post #723793 1st Sep 2025 11:43pm
theJAFman
I have now completed around 1k miles mostly in France.
Car has averaged 19mpg mostly due a heavy playful right foot, best i managed whilst on my best behavior with a family of 5 a loaded boot was 24mpg for a 80mile stretch at mostly 70mph
So in reality after the honeymoon period i should average around 15 mpg i can live with this as the x5 gets 12 😄 🤣
I should have got one sooner! I drove my m3 today after 7 days and 1k miles on the RR and my god the m3 felt a dog to drive!
Likes
The ride its absolutely buttery
This engine really is the standout headline on this car
The torque all 700nm considering a remap...
The size and presence and timeless looks, makes x5s look small even the new ones.
Vdc makes the car very predictable despite being super soft on the initial turn in it stiffens up in the most buttery manner, i cannot imagine how much worse the early gen cars would be in comparison
Unfair Dislikes
1 more gremlin
Interior map lights both front and rear have the same fault.
Right hand side individual light will not turn on im guessing its a ground issue but where!
slight steering wobble around 75 will need to back to the tyre shop and that should be that hopefully
Audio needs to be fixed just a working stock set up will do
Rear entertainment unsure weather to buy the LR headphone and remote the cost seemz silly around 500 or just buy a android screen and forget the rear stuff as kids have tablets switches etc
Car needs a tad more exhaust note to drown out the direct injection motor as it almost sounds like a fancy diesel under 1500 rpm. Unless thats due to the 0w20 oil which seems crazy low weight
Post #724074 6th Sep 2025 3:21pm
theJAFman
In todays shenanigans
Puddle lights, reverse lights and number plate lights all changed to match interior all seems to be high quality flicker free and consistant lighting.
A full wash, clay bar front end followed by 2 stage paint correction and ceramic coating
This car is fairly big ill have to split this correction up
Next washes will be one side each incorporating the boot
Post #724139 7th Sep 2025 8:55pm
theJAFman
Its getting too much love!
As this is the wifes car she wants a girly touch
I suggested hot pink calipers cant think of anything else, any ideas?
Post #724141 7th Sep 2025 9:04pm
firstrr
England 2019 Range Rover Autobiography SDV6 Santorini Black
Keep it simple and easily reversible with a fluffy pink steering wheel cover
Post #724142 7th Sep 2025 9:10pm
theJAFman
Haha 😄 cant get away with that dont care about reversible
Went to get ac refilled and discovered a leak from this rusty looking ac pipe
New part is 225 or a flexi pipe repair kit is 50
Never seen a ac line rust like this wtf
Post #724157 8th Sep 2025 9:12am
theJAFman
I will try removing and welding the pipe for 3.50 before spending 225 if it holds it holds
Then protect that bend with some sort of tubing
Post #724167 8th Sep 2025 10:19am
Gsxr1250dave
Cut it out and replace with copper that's what I did
Post #724210 8th Sep 2025 9:50pm
theJAFman
How did you bond it?
I could make a copper sleeve 10mm and slide it over both sides then solder it ? How did you do it?
Post #724217 9th Sep 2025 8:05am
Gsxr1250dave
Those options just don't work a couple of 10mm compression fitting along with 10mm copper pope did the trick. It was also in the most unexcesible place tucked at the back.
Post #724219 9th Sep 2025 9:01am
theJAFman
Wow literally the same place
I was going to remove the pipe if possible and weld it
Post #724220 9th Sep 2025 9:45am
Gsxr1250dave
No don't bother it never holds just cut the pipe just up past the bend then dissconnect it from the front of the car you can then feed it out carefully giving you something to work with.
Form a new bit of pipe to replace to rotten bit. Reassemble in reverse plumbing compression fittings are best for the high pressure and small enuf to fit in the tight work space.
Post #724225 9th Sep 2025 11:29am
theJAFman
Thank you for the idea
Is it all 10mm
Ally offending pipe 10mm?
10mm copper pipe
10mm compression fittings?
Post #724227 9th Sep 2025 11:50am
Gsxr1250dave
Yeah I'm pretty sure it's all 10mm
Post #724253 9th Sep 2025 8:21pm
