![]() | Home > My Range Rover > L322 5.0 autobiography Sumatra Black - ownership journey |
theJAFman Member Since: 02 Aug 2025 Location: London Posts: 68 ![]() ![]() ![]() |
Its finally done....for Now!
I have now completed around 1k miles mostly in France.
In todays shenanigans
Its getting too much love!
firstrr Member Since: 27 Sep 2024 Location: Lancashire Posts: 36 ![]() ![]() ![]() |
Keep it simple and easily reversible with a fluffy pink steering wheel cover |
Haha 😄 cant get away with that dont care about reversible
I will try removing and welding the pipe for 3.50 before spending 225 if it holds it holds
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1037 ![]() ![]() |
Cut it out and replace with copper that's what I did |
How did you bond it?
Those options just don't work a couple of 10mm compression fitting along with 10mm copper pope did the trick. It was also in the most unexcesible place tucked at the back.
Wow literally the same place
No don't bother it never holds just cut the pipe just up past the bend then dissconnect it from the front of the car you can then feed it out carefully giving you something to work with.
Thank you for the idea
