![]() | Home > Technical (L322) > paddling pool around the compressor in boot !!!!! Help !! :( |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
As bad as it is it's very common. I would start with removing one of those rubber bungs so the water can drain till the source if found. Do you have lights on the "height display" if not it's a dealer/ diagnostic reset. If this is the case remove the compressor and open it up. The black done comes off once the few bolts have been undone. Then you can assess the compressor. It may be ok. Next would be look round the left hand compartment under the rear 3/4 window to see if you can track down the leak. In the mean time run the car with the AC on to dry it out. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
RR8701 Member Since: 11 Aug 2011 Location: East Ayrshire Posts: 380 ![]() ![]() ![]() |
It is really bad, i just keep thinking its meant to be the ultimate 4x4 and the scottish rain has knocked it for 6 |
Bloomin heck thats shocking!!
Might be time to think about 'special' accessories for your FFRR |
come on guys that is not a leak, i think there would be less water if i left the tailgate open
It would be worth removing the compressor and taking the top off to dry the foam padding out, otherwise you could be there for months waiting on it drying. |
If the lights are on don't unplug the compressor without the batt disconnected. If you do it will put a hard fault up and your screwed. The usual place is the glass/seal round rear 3/4, and I've heard of the tale gate seals leaking. Get inside, close up and get someone to drench the area. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
thanks for the heads up, thats a good call...
I've never taken one to bits but it should be straight forward, you will need to remove all 6 bolts I think. Hairdryer would work to help dry it out, just be careful not to get it wet and zap yourself |
You might struggle. The compressor hangs inside the dome on three rubber bush's to reduce vibration noise. When you get time disconnect the batt and remove the compressor. Open it up and dry out with hair dryer or airing cupboard. Fingers crossed when it's dry and batt is reconnected the EAS fault should clear and compressor work. Then it's down to finding the leak. With that much water I would be tempted to remove media gear in the left compartment and give the contacts and block connectors a good clean with contact cleaner. Try and head off some other issues down the line. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Thanks rob, i think this is one for the weekend |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3986 ![]() ![]() ![]() |
To help find the leak I'd be inclined to get some electrical pvc tape and tape up the rear side window on the outside and the adjacent body seams and just wait for some more rain. If you tape up everything the car should be dry inside.
Hi guys.
Have you dried it out yet? Or is it as yesterday but without the pool? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
