Home > Technical (L322) > paddling pool around the compressor in boot !!!!! Help !! :(
Page 1 of 6 123456>
RR8701
United Kingdom 2005 Range Rover Vogue 4.4 V8 Java Black
Hi Guys,
I honestly really need your help, having this RR is like having a stubborn child.
I started the car today and had the air suspension in active warning sign and stayed on, ive seen it once before with hdc inactive but this was prob a poor battery and even when i turn over the car sometimes the screen goes off and comes back on which makes me think the battery is quite poor.
i got quite down about the inactive air suspension warning however i thought it must be the battery and as a test i thought ill disconnect the current one and put it back on and the error was still there. however one thing was really annoying me and that was that there was a lot of condensation in the car and all kinds of craxy electrical reasons came to my head but i thought ill just on the off chance see what the water is like the the boot and look WHAT THE F * * k I SEEN TO MY SHOCK HORROR!!!!
guys what do i do, there is so much water, i have dried it out with towels etc etc, is there anyway i can check if the compressor is working. also how the hell do i stop this from happeneing in the future. this is madness. Sad
:blub:
Post #85702 6th Oct 2011 9:51pm
As bad as it is it's very common. I would start with removing one of those rubber bungs so the water can drain till the source if found. Do you have lights on the "height display" if not it's a dealer/ diagnostic reset. If this is the case remove the compressor and open it up. The black done comes off once the few bolts have been undone. Then you can assess the compressor. It may be ok. Next would be look round the left hand compartment under the rear 3/4 window to see if you can track down the leak. In the mean time run the car with the AC on to dry it out. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #85704 6th Oct 2011 10:02pm
RR8701
It is really bad, i just keep thinking its meant to be the ultimate 4x4 and the scottish rain has knocked it for 6 Sad gutted lol.
anyway luckily for me, all the lights on the suspension setting button/knob area all light up, its currenty kept my normal hiight mode in the lock mode.
i have dried it out with towels and just before your post i thought i would actually do exactly as you said, put the heater on full blast with ac on, leave for 30 minutes and see how it goes tomorrow.
any idea on how i would trace the leak and are there any common areas of leaks?
Thanks rob.
Post #85706 6th Oct 2011 10:06pm
Bloomin heck thats shocking!!
Deffo get the car running with AC and windows closed all the time and track that leak down. Dry the area really well and then leave some dry towel in there, hose the car back 1/4 down and check again to see if you can trace it.
I hope mine never leaks this bad Big Cry
Post #85707 6th Oct 2011 10:10pm
Might be time to think about 'special' accessories for your FFRR Thumbs Up
I like this idea Whistle Whistle
Post #85709 6th Oct 2011 10:13pm
RR8701
come on guys that is not a leak, i think there would be less water if i left the tailgate open
its as if some pregnant ladys water broke in the back, but that i wouldnt mind cause atleast id know where it was from ! LOL
honestly so bad... anyway the car is on full heat, ac on, i just really hope the compressor hasnt packed in, ill honestly be gutted.
Post #85713 6th Oct 2011 10:27pm
It would be worth removing the compressor and taking the top off to dry the foam padding out, otherwise you could be there for months waiting on it drying.
Post #85714 6th Oct 2011 10:30pm
If the lights are on don't unplug the compressor without the batt disconnected. If you do it will put a hard fault up and your screwed. The usual place is the glass/seal round rear 3/4, and I've heard of the tale gate seals leaking. Get inside, close up and get someone to drench the area. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #85715 6th Oct 2011 10:31pm
RR8701
thanks for the heads up, thats a good call...
ill take the top off i think there are three screws and let it dry. then ill hair dryer it for a wee bit i think (or not?) and if need be ill remove the crompressor.
i am assuming its ok to atleast take the top off ? the black dome ?
Post #85717 6th Oct 2011 10:36pm
I've never taken one to bits but it should be straight forward, you will need to remove all 6 bolts I think. Hairdryer would work to help dry it out, just be careful not to get it wet and zap yourself
Post #85719 6th Oct 2011 10:40pm
You might struggle. The compressor hangs inside the dome on three rubber bush's to reduce vibration noise. When you get time disconnect the batt and remove the compressor. Open it up and dry out with hair dryer or airing cupboard. Fingers crossed when it's dry and batt is reconnected the EAS fault should clear and compressor work. Then it's down to finding the leak. With that much water I would be tempted to remove media gear in the left compartment and give the contacts and block connectors a good clean with contact cleaner. Try and head off some other issues down the line. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #85720 6th Oct 2011 10:41pm
RR8701
Thanks rob, i think this is one for the weekend Sad, first thing saturday morning I will strip it down, ill a wee write up too on taken it out etc as i dont think there is one on this forum, would be handy for someone else thinking of having a swimming pool in their tyre well. Razz
cheers
Post #85725 6th Oct 2011 10:55pm
To help find the leak I'd be inclined to get some electrical pvc tape and tape up the rear side window on the outside and the adjacent body seams and just wait for some more rain. If you tape up everything the car should be dry inside.
It's then a case of taking a piece of tape off one at a time and checking after rain to see if the leak has returned. You will eventually find the leak just takes time.
You can use a hose instead of rain but the leak could be so small it might not show up immediately. Looks as though it's been there a while from the amount of water.
Post #85749 7th Oct 2011 8:56am
RR8701
Hi guys.
Any ideas on how to get the compressor working again ?
Post #85769 7th Oct 2011 11:04am
Have you dried it out yet? Or is it as yesterday but without the pool? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #85791 7th Oct 2011 2:22pm
Page 1 of 6 123456>
