Home > Technical (L322) > Air suspension inactive
Page 2 of 7 <1234567>
If light on in middle of dial, you have the setting in lock mode ? Try releasing lock mode so the AS can move up and down. .
Post #170435 6th Feb 2013 9:00am
Paulhh
Scotland 2002 Range Rover Vogue 4.4 V8 Epsom Green
Morning Joe
The light is on in the middle of the dial, not sure how you release it though? I have tried twisting the switch either way but nothing happened. 2002 Vogue Epsom Green with Ivory Leather.
Discover 2 V8
Discovery 2 TD5
Discovery 1 V8
Audi S4 (2005)
Audi S4 (2000)
Post #170438 6th Feb 2013 9:04am
Durham4416
United Kingdom 2003 Range Rover HSE Td6 Zambezi Silver
Nothing happens when I try to release the lock mode, if I try adjusting the height the it just flashes once then nothing happens
Post #170440 6th Feb 2013 9:09am
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
It also locks it if it throws a fault. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #170456 6th Feb 2013 10:38am
Durham4416
I'm wondering if it might be best to leave it until codes have been read rather than deleting he code as chances are it will return? What do you think?
Post #170460 6th Feb 2013 11:19am
JohnnyDangerous
We always read the codes in any vehicle before we re-map it and its not unusual to find quite a few, we erasde them and then take the car for a drive and see if any return before we suck the map out and alter it. It would be nice to know what codes nit has thrown though. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #170462 6th Feb 2013 12:13pm
Paulhh
Mine has just been diagnosed as a front drivers side Height Sensor 2002 Vogue Epsom Green with Ivory Leather.
Discover 2 V8
Discovery 2 TD5
Discovery 1 V8
Audi S4 (2005)
Audi S4 (2000)
Post #170464 6th Feb 2013 12:18pm
Just to confirm, you are trying to move the suspension with all the doors closed?
Post #170465 6th Feb 2013 12:18pm
Durham4416
Yes, it was working perfectly up until yesterday then the 'air suspension inactive' came up on the dash, the light next to normal road height is illuminated, the light on the dial ( the one that comes on when you lock it in position) is also illuminated and it has totally locked the system
Post #170469 6th Feb 2013 12:21pm
Durham4416
Good news Paul, hope mine is as easy Smile
Post #170472 6th Feb 2013 12:23pm
Durham4416
Well just had the garage on the phone and it needs a new compressor, ill post up the actual fault codes when I pick it up, they have quoted me £360 all in for a new unit so I'll have to weigh up my options
Post #170719 7th Feb 2013 3:30pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Seems a lot of money - a compressor only take 20 mins to fit with a 10mm socket being the only tool needed.
Post #170721 7th Feb 2013 3:32pm
Durham4416
Will the fault codes need clearing after? also I'm just concerned if its the battery that's caused it and if I do the compressor myself then I won't have a comeback if its a mid diagnosis,they seem convinced its the compressor but would it throw the same fault if the battery voltage dropped to low?
Post #170723 7th Feb 2013 3:35pm
Durham4416
Meerbusch has quoted me €230 to rebuild my compressor but there is a brand new one on eBay for £225 so probably the better option unless anyone knows of any cheaper rebuild kits?
Post #170724 7th Feb 2013 3:37pm
Durham4416
Just picked it up and the fault code is 'reservoir pressure static when filling' just seems strange as since iv had it the air suspension has always been quick to go up etc but has failed only a week after re calibration, are the demands higher on the compressor now the rear is sitting at the higher, correct height and this is why the compressor is struggling now? The garage have been good to me to be honest as they haven't charged me anything yet but could still do without a £360 bill this month, is it worth stripping and speaking it like in the wiki or is this for different faults? Cheers for the help so far Smile
Post #170741 7th Feb 2013 4:07pm
