Home > Technical (L322) > Air suspension inactive
Page 4 of 7 <1234567>
@ Paulhh
Have you tried a battery disconnect since fitting new sensor, and lock to lock on reconnection?
Also sounds like you may need to recalibrate, do you have that with "AutoBoss" ?
Of course All Comms and IIdTool do this... .
Post #171300 10th Feb 2013 2:47pm
Durham4416
United Kingdom 2003 Range Rover HSE Td6 Zambezi Silver
You to mate, there is a few people on here that really know there stuff when it comes to air suspension so I'm sure someone will have some advice for you but I think a re cal may help, can't do any more harm by the sound of it.
I just hope the garage wont take offence that iv bought a compressor myself, I would imagine iv got less comeback with the garage if they fit a part I bought but the way I see it is the compressor is 10 years old so it can't do any harm sticking a new one on, every time something goes wrong with mine I do find myself looking in eBay for something else but then I think, once all the common faults are done why buy something else with problems Smile
Post #171301 10th Feb 2013 2:47pm
Paulhh
Scotland 2002 Range Rover Vogue 4.4 V8 Epsom Green
Joe
Why would a disconnect of the battery help? I haven't tried that but I have done the steering fully left to right then back to centre and restart but that didn't do anything. 2002 Vogue Epsom Green with Ivory Leather.
Discover 2 V8
Discovery 2 TD5
Discovery 1 V8
Audi S4 (2005)
Audi S4 (2000)
Post #171304 10th Feb 2013 2:49pm
You get a clear down of the ecu's (even more so it you touch the battery terminal connectors together for a while), and then a reset of things when you do lock to lock after reconnection (you'll get Christmas lights on the dash when you start up!!) All the ECU's are in a chain, so everything has to be OK to get no fault codes etc. Your Air Susp Inactive could be being caused by a stored fault or fault somewhere else in the chain (not always necessarily reported!). By clearing things down you get a better chance of spotting it. It is just an option, but worth trying if nothing else is defining the problem. .
Post #171307 10th Feb 2013 2:57pm
Paulhh
Okay Joe, I'll go and try that.
I haven't got the explosive bit on my posi terminal so just to confirm, I can just remove my battery leads without worrying about anything else can't I? 2002 Vogue Epsom Green with Ivory Leather.
Discover 2 V8
Discovery 2 TD5
Discovery 1 V8
Audi S4 (2005)
Audi S4 (2000)
Post #171309 10th Feb 2013 2:59pm
Paulhh
Joe
I'll follow the "how to" in Wiki 2002 Vogue Epsom Green with Ivory Leather.
Discover 2 V8
Discovery 2 TD5
Discovery 1 V8
Audi S4 (2005)
Audi S4 (2000)
Post #171310 10th Feb 2013 3:02pm
Paulhh
I haven't disconnected the battery yet but I did have a look at the valve/actuators and whether they were operating. Dies anyone know whether there is a set sequence of opening and closing valves for going into Off road mode or access mode.
Does each corner pressurise and depressurise separately or do they do it in pairs using the crossovers? 2002 Vogue Epsom Green with Ivory Leather.
Discover 2 V8
Discovery 2 TD5
Discovery 1 V8
Audi S4 (2005)
Audi S4 (2000)
Post #171321 10th Feb 2013 3:55pm
When in Off Road height, the cross over valves should operate so that both fronts (and then both rears) operate together, sharing air, allowing for full articulation but keeping the body as level as possible. It is possible to use the car as a massive and inaccurate spirit level when in off road height Wink .
Post #171344 10th Feb 2013 6:46pm
Paulhh
I have just found that there is no feedback from the front right height sensor, there isn't a fault logged but still no feedback.
No feedback in any height setting.
Strange thing is if I select Access height then the vehicle does lower a bit, I can then keep selecting Access and the car keeps lowering but in small increments taking about 4 or 5 selections to get to full access height. 2002 Vogue Epsom Green with Ivory Leather.
Discover 2 V8
Discovery 2 TD5
Discovery 1 V8
Audi S4 (2005)
Audi S4 (2000)
Post #171349 10th Feb 2013 6:57pm
Durham4416
Just a quick question, the new one iv bought off eBay comes without the turtle (black casing) the part no 'rql000014' seems correct, I assume I am ok using the turtle off my current compressor? Does this actually serve a purpose or is it just for protection? Cheers
Post #171404 10th Feb 2013 11:52pm
djharm
Netherlands 2002 Range Rover Vogue SE Td6 Java Black
just for protection, use the old one.
Post #171440 11th Feb 2013 11:34am
ksmith100
Scotland 2005 Range Rover Vogue 4.4 V8 Java Black
Similair fault!
I have read this thread with interest as my 2005 RR has developed a similar fault. I live in Scotland but was was in Burton Upon Trent all last week. I parked the car in the hotel car park on the Sunday evening and didn't need to use it until the Friday morning to come home, car had driven fine on the Sunday no errors or odd behaviour. Started the car on the Friday morning and got the Air Sus. Inactive message, the car is at normal ride height and doesn't sag. I first thought maybe the battery voltage had dropped (new Bosh 110A battery in June but it had been cold) so drove it a short distance to put some charge back in it and then turned it off and back on and did the steering wheel lock to lock thing, made no difference. Phoned my local Indy as I had along drive and wanted to make sure it was OK to drive, they said if it was level, wasn't making any odd suspension noises then it would be fine, so I drove the 300+ miles back home without a hitch, car drive fine, just didn't lower itself at motorway speeds. I have never heard the compressor in mine work, so I cant say if its that or not, from what I can read if you don't get the accompanying message about speed restriction then the EAS ECU can communicate with the ride height sensors, doesn't mean they are working properly but they are talking to the ECU. I have disconnected the battery and let it sit, reconnected it and got all the lights on, did the steering wheel lock to lock and they all cleared so the steering wheel angle sensor is OK, but the air suspension message remains.
Mine is booked in for Wednesday, I'll let you know what happens!
Post #171445 11th Feb 2013 12:03pm
djharm
Most of the time it is a worn out piston ring witch causes overheating. I fitted the kit from Meerbusch witch was good, although just a new piston ring, and a good clean-out would have been enough I suppose.
Post #171469 11th Feb 2013 1:32pm
Durham4416
I was going to rebuild the compressor but by the time I'd paid for the kit I managed to get a new compressor for the same cost, mine hasn't dropped and in confident enough to keep using it till I get the new compressor fitted
Post #171476 11th Feb 2013 1:57pm
Stuart's the man
read recently over on landyzone a similar problem with resevoir pressure static when filling, guy done a good write up and pictured the repair. it seems it is the valve block in front of the drivers side air tank. one of the valves fks up and causes this fault, which most people diagnose as a faulty pump. cost him 400 for the new assembly.
Post #171478 11th Feb 2013 2:17pm
