![]() | Home > Technical (L322) > Air suspension inactive |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35878
only promoting a site sponsor , whom makes this forum possible by their sponsorship and in my personnel opinion as i have used both the RSW and the IIDTool, its the best value for money out there with the best after service support... ... ... - .- -.
| Jammer600 Member Since: 31 Mar 2013 Location: Bath Posts: 212
Had a bong on turn off yesterday, air sus inactive again but at middle height centre light on nob still off, sus would go up and down steering wheel volume levels not working or next track or cruise control, sinkers not showing on dash either but working externally and radio screen hobby doesn't turn off on vehicle turn off, is this all to do with the inactive sus? |
Anyone there? |
bit of a silly remark that, if nobody knows then nobody will reply..be patient cos not every one is on here all the time.. ... - .- -.
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Requires some translation:
Cheers, most of my mistakes are due to iPhone spell jobby!! Will try the BDP |
| Rich86 Member Since: 10 Mar 2013 Location: Surrey Posts: 509
iPhones and iPads can get you into trouble. 2009 Vogue TDV8 Nara Bronze
Apparently so.
It can be, often associated with battery/alternator issues. Next step is really to get your faults read, find out which bit of the EAS is causing the problem. .
I can hear my air sus compressor starting and stopping over and over a few times, if I go full lock both ways, turn off and start up its gone for about 10-15 seconds then two arrows either side of the display area with nothing in the middle until I turn off and it says air sus inactive, also no stealing controls apart from heated s/wheel and horn work |
| Bofa Bill Member Since: 04 Apr 2013 Location: Poole + Rugeley Posts: 174
My air fault came on while off roading and I was told pump over heating.
| petewild Member Since: 14 Mar 2013 Location: Croydon, Surrey Posts: 45
Hello all.
Sorry, after I posted I remembered, it was such a good write up, it make the wiki page !
| All times are GMT |
