![]() | Home > Technical (L322) > Air suspension inactive |
daz62 Member Since: 27 Dec 2011 Location: Reading Posts: 201 ![]() ![]() ![]() |
Try the search facility on here with, "air suspension inactive" and you will be reading about it and how to sort it for days to come.
Durham4416 Member Since: 10 Dec 2012 Location: Middlesbrough Posts: 248 ![]() ![]() ![]() |
I tried searching but just found posts with people having all the lights out on the dash (for the air suspension) or car dropping on one of the corners but my symptoms are slightly different, I will try having another look, cheers |
I seem to remember the lights on the controls do just stay on when it is inactive, but control is disabled. 03 4.4 V8 petrol / lpg. 1st of many hopefully. I love my Rangie |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
Bit of a long shot here.. Have you tried turning the steering wheel all the way to the left, hold it for a second or 2, then turn it all the way to the right? When I recently had a flat battery the suspension would not work until I had done this to reset the steering sensor, it then fired up the comp. as well. Just thought your battery might have let go a bit.. |
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 ![]() ![]() ![]() |
Check your battery and all connections at the terminals, cold weather can kill a bat at the drop of a hat, you can prob reset the lights by dissconecting both bat terminals and touching them together to erase the memory from the ecu. One day your life will flash before your eyes......................................make sure yours is worth watching!
Cheers for the reply, iv tried that to no avail, to b fair the battery could be on its way out as iv occasionally had 'hdc inactive' on start up since I got it, is it possible the voltage has finally dropped to low and locked me out? I'm hoping its a height sensor as it was fine till I got it re calibrated although that could just be a coincidence, I soppose I won't know until I get the fault codes read on Thursday, I did do a little light off roading the other day so maybe a height sensor as got covered in crud? Clutching at straws I think lol |
I will try disconnecting the battery tomorrow, so I need to touch the connectors together to reset? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35849 ![]() ![]() |
that info is in the wiki.. |
Cheers just seen it, dosen't mention touching the teminals in there so just wanted to check that I just touch them together to reset? Cheers |
Yes disconnect both and touch them together, it will clear the codes, if it immediately says the same fault, do the same but put a charge in the Bat, if the lights stay off the problem is low voltage. One day your life will flash before your eyes......................................make sure yours is worth watching!
Monty1 Member Since: 07 Oct 2012 Location: Middlesbrough Posts: 181 ![]() ![]() ![]() |
had this with mine and it was the eas pump |
Did you fit a new compressor? |
Paulhh Member Since: 23 Dec 2012 Location: Carrbridge Posts: 143 ![]() ![]() ![]() |
I've got the same. I got this error and found a broken height sensor, had to replace the rear right height sensor and since then I've still got this error message. The Indy cleared it and it disappeared for 3 trips now back again. Heading to Indy tomorrow to see what he says. 2002 Vogue Epsom Green with Ivory Leather.
i did and also had a faulty sensor |
