Home > Technical (L322) > Key won't turn in ignition fix 2002-2005 |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
This has been an ongoing problem for some time, the key goes in the ignition but the steering lock doesn't go off so it won't let you turn the key to start the engine, the "get you home" fix was to remove and insert fuse 18 and the system resets, this works if the lock is stuck in the off position, if it sticks in the locked position you've had it, it's a new column as JLR don't sell bits... This runs into thousands...
1st Nov 2016 12:56pm |
builder1966 Member Since: 23 Aug 2016 Location: ashingdon Posts: 299 |
well done pete brave man taking that lot apart forsure |
1st Nov 2016 2:28pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
Great work Pete Nice detailed photo howto, will no doubt have been wikified before I finish typing this .
1st Nov 2016 6:08pm |
Thanks chaps..
1st Nov 2016 6:17pm |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Brave lad pete.
1st Nov 2016 7:52pm |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 586 |
think you should open a garage pete |
1st Nov 2016 8:11pm |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 |
well done mate GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
1st Nov 2016 8:33pm |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 |
could you not just remove the locking pin (blue end) leave the motor in place ? |
1st Nov 2016 10:56pm |
Thanks chaps, someone had to do it.... It's a fairly simple system and I've searched for spares but apart from the magnet there is nothing out there, Johnson make the motor but it's not listed on their website, Kuhnke make the solenoid but won't sell them.
1st Nov 2016 11:20pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Does anyone know if they are common to any BMW models... it could be a cheaper source... especially if S/H... they don't seam to carry the Range Rover mark up Yesterday I couldn't spell Engineer... Today I are one!
2nd Nov 2016 12:11am |
I searched all the BMW models around that era and all their ELV's are different... Sods law...... Pete
2nd Nov 2016 1:10am |
I'd have thought that late 90's 7 series would have been a good source... they seem to nicked most of the tech from there Yesterday I couldn't spell Engineer... Today I are one!
2nd Nov 2016 9:04am |
They are all similar but different, even between the BMW's... Pete
2nd Nov 2016 11:22am |
Gits ... Shafted again by Beamer Yesterday I couldn't spell Engineer... Today I are one!
2nd Nov 2016 11:53am |
