Home > Technical (L322) > Key won't turn in ignition fix 2002-2005 |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7924 |
PM sent Pete
5th Jun 2017 2:34pm |
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 |
Pete, did I send you the link to the US magnet supplier? I can't find it in my email but would be happy to post here if I can remember your email address to search for! |
5th Jun 2017 4:32pm |
I'd forgotten where I got the info...!!! I'll PM you my email address feel free to post the link... Pete
5th Jun 2017 7:22pm |
Thanks Pete, found the message. This was the info I'd found:
6th Jun 2017 1:23pm |
themule Member Since: 03 May 2016 Location: Yorkshire Posts: 126 |
Thanks very much for the link dingg - have you tried that method? Mine is 2007, it seems odd if the column lock has changed from earlier models it still suffers from the exact same problem. I have never experienced it or heard of it on any other car. |
7th Jun 2017 10:01pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1273 |
hi
7th Jun 2017 10:31pm |
This method of disconnecting the module does work and is easy. I tried with 2 needles and shorted the 2 pins together and I could start the car fine. Im not sure what to do next - can I leave these 2 wires shorted permanently, will that drain the battery or do I need a switch. Im certainly not driving around with 2 sewing needles stuck a few inches above my knee I need something more permanent.
8th Jun 2017 10:08pm |
I would wire in a rocker switch permanently to those pin positions and locate the switch under the column shroud so its invisible to everyone - glad to hear it works could save a lot of faffing about and expense |
9th Jun 2017 8:01am |
AKIS Member Since: 23 Apr 2009 Location: GREECE Posts: 186 |
My steering lock failed open.Right now for starting car i have to first remove fuse 18.
15th Jun 2017 12:19pm |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 285 |
@Haylands, the solenoids had arrived, many thanks. Normal I would buy them also in US, but they want 20$ shipping.....
16th Jun 2017 12:42pm |
By reading better thread i saw that pinning of 1 and 7 of c2055 can have an effect only to non bmw models.
16th Jun 2017 2:03pm |
Yep, jumping pins only works with the later models...
18th Jun 2017 9:18pm |
Haylands thanks for your reply.Decided to buy second hand steering column for fitting and will try to open ecu of damaged one to see if can repair it.
21st Jun 2017 12:22pm |
AFAIK it's all plug and play, no ECU's in it, just motors, solenoids and a few other unreliable items......
21st Jun 2017 12:43pm |
