Home > Technical (L322) > Front suspension thump |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
Box of matches?
19th Dec 2011 10:26am |
rads Member Since: 04 Sep 2011 Location: Herts Posts: 157 |
Gaaaah.
20th Dec 2011 12:16pm |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
I go into dunlop were they test and put there struts together they make them in coventry ive seen the testing they do and the workmanship is second to none onto no6 Range Rover Everyone needs a hobby |
20th Dec 2011 1:48pm |
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 |
My car started knocking on the front near side recently. It wasnt a heavy thump, more a light knocking over uneven ground, also noticed it if i wiggled my steering wheel from side to side when driving along. I took it to my local garage and they had a look underneath, the near side link rod was the culprit, they also noticed that the lower track rod bush on the same side had a lot of play (I was under the hoist too so could see everything - which is nice as you don't feel ripped off).
20th Dec 2011 11:37pm |
Glideman Member Since: 11 Sep 2011 Location: Stood next to a broken down Range Rover in Darwen Posts: 112 |
Just noticed this thread http://www.fullfatrr.com/forum/topic7044.h...sion+knock
I wonder if this could be the problem? Has anyone got a picture or diagram of the parts? I'm pretty sure mine had no hard washers fitted & this could be the problem Range Rover 4.4 V8 Vogue |
21st Dec 2011 12:00am |
One hard washer for each drop link, would need to check with Rave, but from memory goes on the joint side at the top, opposite side to the nut.
21st Dec 2011 12:29am |
No I'm still waiting for you to do yours to find out if it stops The washers must be missing on mine, been out to check the old strut to see if the washer was stuck to it, but it wasn't. It does seem worth checking though, or maybe not Range Rover 4.4 V8 Vogue |
21st Dec 2011 2:22am |
Very quick and cheap to add the washers, nothing much to lose!
21st Dec 2011 8:06am |
I swapped the the old strut top gasket over so that can probably be ruled out. Starting to run out of things to change now (not doing the rack) I can't drive it round knocking and the dealer, myself and a none franchised garage can't find the knock, maybe it's time to get rid Don't know what to replace it with though, still seems ridiculous that none of us can find where a loud knocking is coming from Fed up of throwing time & money at it
21st Dec 2011 10:57am |
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 |
Have you done the anti roll bar bushes? |
21st Dec 2011 11:01am |
No not done them yet but I have had it up on a ramp with three different garages & none could see any play in them. I've recorded a film on my phone of the noise which I'll put on YouTube with a link on here if that's allowed. Can't find a way to post it here. Range Rover 4.4 V8 Vogue |
21st Dec 2011 11:07am |
Here's a thought.
21st Dec 2011 12:00pm |
That does sound the same as mine, may try removing the drop link. Should eliminate the anti-roll bar bushes to I would think. The phone thing could help if it's gaffer taped to various parts of the suspension. It may destroy the phone but it's probably cheaper than buying a new Range Rover in spare parts Range Rover 4.4 V8 Vogue |
21st Dec 2011 2:25pm |
This is the video I made today of the knock the rattle is just the camera phone mount Range Rover 4.4 V8 Vogue |
21st Dec 2011 4:29pm |
