Home > Technical (L322) > Air suspension inactive
Page 1 of 7 1234567>
Durham4416
United Kingdom 2003 Range Rover HSE Td6 Zambezi Silver
So iv had my 2003 hse for a few months and never had a problem with the operation of the air suspension but it was sitting a little low at the rear so I had it re calibrated at my Indy last week, everything has been fine and iv used the suspension up and down a couple of times in which it rises and drops quickly, anyway wife got in it this morning and 'air suspension inactive', it's still doing it now when I had just checked, the light is in in the middle of the dial and the light next to the standard road height setting is illuminated but nothing is working? Any ideas? Iv phoned my Indy and its going back on Thursday afternoon for a check over buy anybody had the same problem?
Post #170256 5th Feb 2013 5:32pm
daz62
United Kingdom 2003 Range Rover Vogue SE 4.4 V8 Oslo Blue
Try the search facility on here with, "air suspension inactive" and you will be reading about it and how to sort it for days to come.
It could be one of a number of problems, split airbags, iffy height sensors or dicky compressor to name just three.
Most are relatively easy to get sorted.
Here is a link to a recent air susp thread.
http://www.fullfatrr.com/forum/topic15832....n+inactive
good luck 03 4.4 V8 petrol / lpg. 1st of many hopefully. I love my Rangie
Post #170263 5th Feb 2013 6:41pm
Durham4416
I tried searching but just found posts with people having all the lights out on the dash (for the air suspension) or car dropping on one of the corners but my symptoms are slightly different, I will try having another look, cheers
Post #170264 5th Feb 2013 6:45pm
daz62
I seem to remember the lights on the controls do just stay on when it is inactive, but control is disabled. 03 4.4 V8 petrol / lpg. 1st of many hopefully. I love my Rangie
Post #170298 5th Feb 2013 8:33pm
Bit of a long shot here.. Have you tried turning the steering wheel all the way to the left, hold it for a second or 2, then turn it all the way to the right? When I recently had a flat battery the suspension would not work until I had done this to reset the steering sensor, it then fired up the comp. as well. Just thought your battery might have let go a bit.. Thumbs Up Previously..
Post #170299 5th Feb 2013 8:37pm
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
Check your battery and all connections at the terminals, cold weather can kill a bat at the drop of a hat, you can prob reset the lights by dissconecting both bat terminals and touching them together to erase the memory from the ecu. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #170301 5th Feb 2013 8:45pm
Durham4416
Cheers for the reply, iv tried that to no avail, to b fair the battery could be on its way out as iv occasionally had 'hdc inactive' on start up since I got it, is it possible the voltage has finally dropped to low and locked me out? I'm hoping its a height sensor as it was fine till I got it re calibrated although that could just be a coincidence, I soppose I won't know until I get the fault codes read on Thursday, I did do a little light off roading the other day so maybe a height sensor as got covered in crud? Clutching at straws I think lol
Post #170302 5th Feb 2013 8:46pm
Durham4416
I will try disconnecting the battery tomorrow, so I need to touch the connectors together to reset?
Post #170303 5th Feb 2013 8:47pm
that info is in the wiki.. Wink ... - .- -.
Post #170312 5th Feb 2013 8:57pm
Durham4416
Cheers just seen it, dosen't mention touching the teminals in there so just wanted to check that I just touch them together to reset? Cheers
Post #170315 5th Feb 2013 9:00pm
JohnnyDangerous
Yes disconnect both and touch them together, it will clear the codes, if it immediately says the same fault, do the same but put a charge in the Bat, if the lights stay off the problem is low voltage. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #170329 5th Feb 2013 9:39pm
Monty1
England 2005 Range Rover Supercharged 4.2 SC V8 Rimini Red
had this with mine and it was the eas pump
Post #170332 5th Feb 2013 9:43pm
Durham4416
Did you fit a new compressor?
Post #170338 5th Feb 2013 9:59pm
Paulhh
Scotland 2002 Range Rover Vogue 4.4 V8 Epsom Green
I've got the same. I got this error and found a broken height sensor, had to replace the rear right height sensor and since then I've still got this error message. The Indy cleared it and it disappeared for 3 trips now back again. Heading to Indy tomorrow to see what he says. 2002 Vogue Epsom Green with Ivory Leather.
Discover 2 V8
Discovery 2 TD5
Discovery 1 V8
Audi S4 (2005)
Audi S4 (2000)
Post #170398 6th Feb 2013 12:04am
Monty1
i did and also had a faulty sensor
Post #170408 6th Feb 2013 2:03am
