![]() | Home > Technical (L322) > Air suspension inactive |
| Durham4416 Member Since: 10 Dec 2012 Location: Middlesbrough Posts: 248
Lol he misses the bit out about removing it from the shell, it looks like you can though, just spoke to a friend at landriver main dealer and he said iv bought the wrong one as only the later ones separate from the shell :s |
| T111RDY Member Since: 21 May 2012 Location: Dunbar Posts: 187
No, you can definitely do this - there is a member on here Meerbusch, who sells repair kits on eBay.
| djharm Member Since: 28 Dec 2012 Location: breda Posts: 78
It's glued, just put a screwdriver between the shell and the bottom plate. cars on the side;
You can see it where the cable comes out. I did fit the Meerbusch kit. cars on the side;
And I have a 2002, so it can be separated. cars on the side;
I assumed that's how you did it but I was worried about busting it, cheers, turns out the compressor wasn't posted when they said it was so it won't arrive till tomorrow, after lots of hassle iv agreed with parcelforce that they don't put it on the van and I will collect it first thing in the morning then drop it off at the Indy for them to fit and clear the codes, hopefully it will work, fingers crossed then I can head up to Scotland |
Another twist to the tale for god sake!
| axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964
Durham4416 you may well have the wrong compressor there these parts were handled by Finning the Caterpillar people (don't know if they still are ) and they got a whole lot incorrectly boxed up . 2008 MY Supercharged
I bought it off eBay, it was advertised as an 02-05 compressor when it is in fact a 2006- one, I'm trying to get a refund as its not as described and then I am just going to get my Indy to supply and for one on Monday when I get back, in just hoping the suspension stays up as it seems to have dropped a little , I was contemplating disconnecting the battery to try and clear he fault codes and see if the compressor would manage to just lift it back to standard road height but not sure if its a good idea or not :s |
if you clear the faults it will probably work again for a couple of day's. you can't clear the faults by disconnecting the battery though. Has to be done with a computer. cars on the side;
| Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 327
@djharm, very happy and proud, that my kit helps you and your problem, always good drive!!! Best regards, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + L322 TDV8 2011 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
| petewild Member Since: 14 Mar 2013 Location: Croydon, Surrey Posts: 45
Hello all sufferers of the AIR SUSPENSION INACTIVE ding dong
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
we are most aware of a company called GAP diagnostics who are in fact site sponsors...
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048
Now now Stan!!! you being a Mod shouldn't be promoting one single product )unless backhanders were given) when there are several 'similar' products. It's up to each individual to do his own research |
| All times are GMT |
