Home > Technical (L322) > Air suspension inactive
Page 7 of 7 <1234567
petewild
England 2002 Range Rover HSE 4.4 V8 Java Black
As I said earlier, I wasnt trying to tell you something you didnt already know about, moreso I was offering anyone who was stuck with the message, and didnt want to pay for the dealers holiday, a free reset
Post #178156 18th Mar 2013 10:31am
only promoting a site sponsor , whom makes this forum possible by their sponsorship and in my personnel opinion as i have used both the RSW and the IIDTool, its the best value for money out there with the best after service support... ... ... - .- -.
Post #178158 18th Mar 2013 10:34am
Jammer600
2009 Range Rover Vogue TDV8 Buckingham Blue
Had a bong on turn off yesterday, air sus inactive again but at middle height centre light on nob still off, sus would go up and down steering wheel volume levels not working or next track or cruise control, sinkers not showing on dash either but working externally and radio screen hobby doesn't turn off on vehicle turn off, is this all to do with the inactive sus?
Post #185309 28th Apr 2013 5:06pm
Jammer600
Anyone there? Smile
Post #185482 29th Apr 2013 1:46pm
bit of a silly remark that, if nobody knows then nobody will reply..be patient cos not every one is on here all the time.. ... - .- -.
Post #185494 29th Apr 2013 2:24pm
Requires some translation:
nob = knob
Air Suspension Knob light should only come on if you press it to fix the suspension height. When off you can adjust heights (as you say you can)
sinkers = winkers = indicators
radio screen hobby = radio screen jobby = radio screen
Have a feeling you have something wrong in the ECU chain somewhere. Suggest a battery disconnection procedure (see wiki) as a first port of call, then if that doesn't work connect up to Testbook/IIDtool etc. .
Post #185538 29th Apr 2013 5:48pm
Jammer600
Cheers, most of my mistakes are due to iPhone spell jobby!! Will try the BDP Wink
Post #185599 29th Apr 2013 8:12pm
Rich86
United Kingdom 2009 Range Rover Vogue TDV8 Nara Bronze
iPhones and iPads can get you into trouble. 2009 Vogue TDV8 Nara Bronze
2002 Vogue V8 Zambezi Silver
1986 90 Pick up Deep Bronze Green
1978 Series III SWB Deep Bronze Green
Post #185604 29th Apr 2013 8:16pm
Jammer600
Apparently so.
I've just carried out the said method, to no avail, my main question is, is it common to have the fault "air sus inactive" with all the other things? Cheers
Post #185624 29th Apr 2013 9:07pm
It can be, often associated with battery/alternator issues. Next step is really to get your faults read, find out which bit of the EAS is causing the problem. .
Post #185641 29th Apr 2013 10:07pm
Jammer600
I can hear my air sus compressor starting and stopping over and over a few times, if I go full lock both ways, turn off and start up its gone for about 10-15 seconds then two arrows either side of the display area with nothing in the middle until I turn off and it says air sus inactive, also no stealing controls apart from heated s/wheel and horn work
Post #185651 29th Apr 2013 10:29pm
Bofa Bill
Scotland 2003 Range Rover SE Td6 Epsom Green
My air fault came on while off roading and I was told pump over heating.
Which, after letting it cool it was back to normal.
I concluded that the pump being encased in the shell was working as it should but being off roading the pump was working 'overtime' and overhet.
Cure?
Bought a new pump assemble and put some copper water 15mm pipes as a spacer in the join of the pump shell to allow fresh, cooler air in.
All seems fine noo
Hope ye get yours sorted Made in Scotland frae 'Girders'
Post #185677 30th Apr 2013 1:56am
petewild
Hello all.
Not sure if this is the correct way to ask, but I read a bloody good write up, with pictures, on here 'somewhere' regarding the refurb of the suspension compressor, more than the standard piston ring change, this write up stripped out the silicon gel? Dried it out etc and replaced.
Now I actually want to do it, do you think I can find the thread !!! Big Cry
Anyone have any ideas?
Thanks
Post #233949 10th Jan 2014 11:31am
petewild
Sorry, after I posted I remembered, it was such a good write up, it make the wiki page !
Found it now Embarassed
Post #233952 10th Jan 2014 11:53am
