Home > Technical (L322) > 3.6 TDV8 issues following split boost/intercooler hose |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
Thinking on this - if removing the bottom hose kind of relieves the issue for a short while, I wonder if there's something in the intercooler and removing the pipe is allowing any pressure to drop and the blockage move (although quite what could in the intercooler apart from oil I'm not sure!) Land Rover Addict
4th Apr 2019 10:50am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3194 |
@ MW
4th Apr 2019 10:51am |
Genuine hoses come with the clips - I am guessing the silicon ones don't .... Land Rover Addict
4th Apr 2019 10:54am |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
DMRR, I think its the top hose that is being removed and replaced. He also put a new genuine LR hose on at first.
4th Apr 2019 11:03am |
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 |
Are you leaving the plastic top engine cover off?
4th Apr 2019 1:03pm |
ok, the split is typical. Usually under the webbing sleeve.
4th Apr 2019 1:10pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1692 |
Have you taken the bottom hoses off yet? |
4th Apr 2019 1:18pm |
Just to be clear here on diagnostics - are you using IID (or equiv), or just an OBDII reader?
4th Apr 2019 1:19pm |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 593 |
Bottom hoses have been off and checked mikey.
4th Apr 2019 2:49pm |
Any news Mariana? 2007 3.6 TDV8 |
7th Apr 2019 12:03pm |
Sorry ive not updated,
8th Apr 2019 10:01am |
Right, back to it.
10th Apr 2019 10:08pm |
Helps if I add the picture... doh |
10th Apr 2019 10:09pm |
Third times the charm.. is it possible to edit posts?
10th Apr 2019 10:10pm |
