![]() | Home > Technical (L322) > 3.6 TDV8 issues following split boost/intercooler hose |
Thinking on this - if removing the bottom hose kind of relieves the issue for a short while, I wonder if there's something in the intercooler and removing the pipe is allowing any pressure to drop and the blockage move (although quite what could in the intercooler apart from oil I'm not sure!) Land Rover Addict
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3271 ![]() ![]() ![]() |
@ MW
Genuine hoses come with the clips - I am guessing the silicon ones don't .... Land Rover Addict
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
DMRR, I think its the top hose that is being removed and replaced. He also put a new genuine LR hose on at first.
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 ![]() ![]() ![]() |
Are you leaving the plastic top engine cover off?
ok, the split is typical. Usually under the webbing sleeve.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1863 ![]() ![]() |
Have you taken the bottom hoses off yet? |
Just to be clear here on diagnostics - are you using IID (or equiv), or just an OBDII reader?
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 757 ![]() ![]() |
Bottom hoses have been off and checked mikey.
Any news Mariana? 2007 3.6 TDV8 |
Sorry ive not updated,
Right, back to it.
Helps if I add the picture... doh |
Third times the charm.. is it possible to edit posts?
