Home > Technical (L322) > 3.6 TDV8 issues following split boost/intercooler hose |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 593 |
21st Apr 2019 3:23pm |
After a bank holiday Monday of rolling around on the floor swearing the short PCV hose is now firmly attached with 2 hose clamps.
23rd Apr 2019 7:54pm |
Right, car back with a report from the specialist.
27th Apr 2019 7:13pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1688 |
Are you able to read the live values of the EGR valves?
28th Apr 2019 9:10am |
Hi Mikey,
28th Apr 2019 9:13am |
An early start this morning,
28th Apr 2019 9:28am |
I'd be inclined to remove the EGR blanks. The PCM expects to see a drop in MAF values when the EGR's open...
28th Apr 2019 9:31am |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
This is one of the strangest problems ever.
28th Apr 2019 12:19pm |
This was the trace from the one I had in
28th Apr 2019 12:39pm |
I am sure the EGRs can be ruled out of this Mikey as they are phsyically blanked and unable to recirculate into the intake as well as being mapped out in the cars software.
30th Apr 2019 10:07am |
So, you had no issues prior to remap and blanking
30th Apr 2019 12:18pm |
I had the check engine light on for an EGR issue, had them blanked and mapped out.
30th Apr 2019 12:22pm |
Quantum is a decent map. I and a few others on here have their map without issues so it probably isn"t your issue. I wasn't sure you knew the history of it which is why it was suggested.
30th Apr 2019 1:55pm |
Have you checked MAF sensor values.
30th Apr 2019 2:22pm |
